Hi !
I am running a simulation for an assembly with SW2012. Parts are connected with bolt connectors.
At first, there was no pre-load in the bolts. The calculation succeeded using the iterative solver.
Then, I added pre-loads. Now I am getting a Status code 9 (matrix singular or ill-defined). It says I should use the Direct solver, which I tried, but I'm running out of memory to complete the calculation.
Any suggestion about how I could make this work with the iterative solver ?
Astrid.
Don't use bolted connections at all. Make a split face where the bolt would contact, apply your pre-load clamping force and solve. (This gives a 'better' answer anyway.)
