I'm building a rout and I've got 2 co-linear lines that come together. That makes 2 pipes with a but joint when I really want 1 pipe. How do I combine those pipes?
If I attempt to delete one line and extend the other the sketch goes haywire.
Adam,
I am assuming that you have a tee-pipe-flange connection and the point is not made using split route. If I am correct, my usual work around is delete the line on the tee's side and make a merge relation between points (center of the tee and the dangling end point from the flange).
Hope this works for you.
-Jose
Adam,
-Jose
