I am trying to link the Sheet Metal Gauge to the part thickness so that I can then link this in a part drawing. I have a gauge table with the Gauge No. and Gauge(Thickness). Does any one know how to do this?
Hello Aaron,
What you are trying to do is not possible by default. The only way you can achieve this is by reading in the thickness of your sheetmetal then match it to a gauge table and enter custom property. All this requires api and needs to be run every time you change thickness & units.
No other way.
Elmar
Every time!!!!! The only reliable way is to read the sheetmetal thickness and compare with gauge table...then add the corresponding GA designation as custom or config property. We pick thickness from design table that also links to gauge size. That works too, make changing thickness of sheetmetal a little slower since I have to open the DT everytime, but guarantees proper & uniform BOM's. Has the limitation that you can't use gauge tables in the sheetmetal features. Not a requirement in my line of work. Heavy industrial equipment that is....
Here is the sheet metal gauge sizes chart:
Sheet Metal Gauge Sizes Chart - inch/mm (2018 Updated) | MachineMfg.com
I was able to get the gauges linked to the thicknesses by modified one of the Solidworks provided tables "k-factor inches sample". I chose to only include the sheet sizes my company uses and the K-factors we had determined for our presses. Getting the thicknesses to show up on the drawing, however, I still haven't worked out all the kinks on that one.
Add a excel sheet metal table to your part template -
