I have an imported solid that has an extra solid portion in a thru hole that I'm trying to get rid of. I tried Import Diagnostics, that couldn't fix it. I tried converting the hole to a sketch and doing an extruded cut (with sketch offset, plane offset, etc), no luck, says the operation failed due to geometric conditions. I tried filling the hole in so I could possibly redo the hole, but got the same error. I even tried the hole wizard, but it says the intended hole doesn't intersect the model, even though I can see the transparent yellow preview solid intersecting the piece I'm trying to delete. I've attached the model, along with a screenshot pointing out the problem holes. Let me know if you guys need any more info. Thanks!
William,
Try an Import diagnostics and select the option "Attempt to Heel All"
It's working OK for me
