I am currently trying to complete the SEK (Student Engineering Kit) form to download Solidworks, but the 2014-2015 version is not available. I only have a serial code good for this version. Where can I find the 2014 installer?
If you have a code for the 2014 version it's probably expired. The codes that are available can be used for all currently available downloads, it usually doesn't mattter which version you choose to download. I would try the 2015 version if you need an older version, otherwise select the 2016 version.
It would be hard to find online unless someone has the installation files available. Have you checked with local VAR in your area?
Also note sure if that would work as generally these are one year licenses only (not fully sure)
