Before I bought Solidworks, I saw this cool video where someone laid out a basic outline of a building(bus shelter) and then replaced the lines with channel of different sizes and added on tabs and used glass as fill ins etc.
I would like to do something similar. But I can neither find the video nor written instructions.
I have Solidworks Pro, which I got assured has the right features to do that kinda stuff.
Help/Instructions please?
Hi Sabine,
Weldments is most definitely thewhat you need to use. If you want to look at the tutorials you can find them by going to the help drop down in solidworks and clicking on solidworks tutorials. Once you click on this a side pane to the right will appear and show you numerous different tutorials about aspects of the software.
The weldments tutorial can be found by clicking on the basic techniques tab located in top centre row of the right hand pane and by then clicking the weldments window.
Once this is done it will take you directly to the start of the tutorial and will direct you how to download anything you require.
If you do not have the weldments toolbar active in solidworks you can activate it by right clicking on any tab i.e where it says 'features' or 'sketch' on the toolbars and a pop up will appear left click on the weldments line and this will add the wanted toolbar with the features you need.
below I have attached a photo of the pop out that should appear.
Hope this is of help
thanks tom
