My name is Charles, I've just taken over a Design Team that uses SolidWorks, I've come from an Inventor background using Vault.
I need to establish the Vault system through the our main server here, what is the best method to achieve this ??
I want each user to work in their own drives utilising library parts and assemblies from the server library and then at the end of any significant model change, check back into the vault that updated assy or part.
I realise that is a large request for instructions, so just an overall set of instructions would be great.
Thank you.
Thank you.
You need PDM to work for you. PDM works the same way as Vault does in Inventor.
