Ok, I have a 4" diameter rubber ball in free space 2 inches
above a .5 inch thick steel plate. I apply gravity and drop the
ball. Everything I've tried setting all frame rates to max, 3-d
contact resolution to max etc. and still the ball passes right
through the plate.
I've left the properties as acrylic and/or chaged them to rubber and steel. THe only way I can make the 3-d contact work is Physical simulation. What I really want to is have the ball bounce as it should!
Any suggestions?
Any suggestions?
You need to reduce the "Maximum Integrator Step Size" (Motion Study Properties-> Advanced Options).
Shrikant
