Can anyone give me an explanation on what happens when
validate vault is set to at next startup? If I understand
correctly, once the server is restarted, the first person to login
to PDMWorks will kick the validation off on that workstation, and
will have a pop up showing as it is going through the validation,
is that correct?
Quoted from PDMW Admin Help File;
On Vault Startup
Validate vault. PDMWorks goes through each project in the Vault to make sure every document is valid. Choose to go through the procedure at:
Next startup. The option to Validate vault is cleared after the next successful validation.
Every startup
! The Vault is validated at every installation and upgrade without regard to the option settings.
* Question 2-
Incorrect, the validation process is silent and starts after server service starts. No user can even login until this is completed. No popup window will launch, you have to look at the vault log.
