I have an assembly with about 20 configs and 250 parts. For
some reason, the custom properties in a few of the configs are now
gone. Anyone know what happened? In case you were wondering, this
assembly crashes about every half hour. Is there a way to copy and
past the custom properties from a working config to the ones that
lost them?
Thanks in advance,
Steven
Thanks in advance,
Steven
Steve,
The easiest way to delete information from multiple configurations is to overlook the "All Configurations" selection when deleting something from one configuration.
The simplest way to input & maintain Configuration Specific Properties is to control your database using a design table.
Steven
Now, it's a little funny how this works and I chalk it up to bad interface coding but here's how it works.
With the document open in Solidworks go into custom properties and select the configuration specific tab. Activate your source configuration from the list box. Highlight the rows you want to copy from the property grid by dragging down the row headers. CTRL+C. Switch to the destination configuration. Pick on the first row header so that the row highlights and CTRL+V. Now here's the weird part.
Pick in the value field of the first row and hit the TAB key. The second row will appear below the first. Go to the value field of the second row and hit TAB and the third row will appear. Rinse and repeat until all of the property rows are visible.
you're populated. Solidworks will balk if there are any duplicate property names. It's generally better to clean those up before you paste.
CAD naked
John
