0 Replies Latest reply on Aug 22, 2008 2:07 PM by 1-BS5DTB
    hole table
      Is there a way when creating a hole table to select all faces?
      i have a plate with keyways that are 1/2" deep and the hole table wont pick up the taps in the keyway if i dont go in and select every keyways individual face which the taps lay on.
      also i would like the hole table to pick up the work on the opposite side to add to the same hole table, but as far as i can see you can do this from 1 view, you would have to create multiple views(front & back) to achieve this.
      i would like to select all holes on all faces from picking one view.
