I'm trying to write a macro to add reference points to multiple pre-selected edges. I'd like to be able to cycle through so that i can add the points both evenly distributed along the edges and at the intersections.
Basically, i'm pulling point clouds off of splines and exporting them to excel for manipulation. I have the excel part down, but i'm currently manually adding the reference points. Would like to be able to just select the multiple edges and have a steady distribution across all selected edges.
bonus points: not really a math guy, but is there a way to determine if an edge is a more or less extreme curve? I'd rather have more points on the "bendier" splines and fewer on the straight ones. If not, I can live with that.
Hi Sean. Amen Allah Jlili is right and only one edge need to be selected at a time for this operation. Try to use this code
Dim swApp As Object
Dim swModel As Object
Dim numSel As Integer
Dim selType As Integer
Dim vRefPoint As Variant
Set swModel = swApp.ActiveDoc
Dim swSelData As SldWorks.SelectData
Set swSelData = swSelMgr.CreateSelectData
Dim egdeColl As New Collection
numSel = swSelMgr.GetSelectedObjectCount2(-1)
For i = 1 To numSel
selType = swSelMgr.GetSelectedObjectType3(i, -1)
If selType = 1 Then
Dim edgeEntity As Entity
Set edgeEntity = swSelMgr.GetSelectedObject6(i, 0)
egdeColl.Add edgeEntity
Next i
For i = 1 To egdeColl.count
egdeColl(i).Select4 False, swSelData
vRefPoint = swModel.FeatureManager.InsertReferencePoint(2, 2, 0, 8)
Next i
Regards
Viktor
