API Creating File Reference
Question asked by Matthew Lee on Jul 21, 2016
Latest reply on Jul 21, 2016 by Matthew Lee
Okay I know this seems simple but I have not been able to figure it out. I have read all the fourms and sample codes and have still not made any headway towards a solution. Basically what I have is a code that will read in a variable value from a card (this value has a list of documents [":C\Test\A.sldprt" ":C\Test\B.docx" ":C\Test\C.pdf"]). The code then decomposes the string into a new string, that is the same length as the number of files, and each segment has the file path. I then want to attach the each of those files as a reference to the current parent file. Any ideas????
Imports EdmLib
Module Module1
    Sub Main()
        'Creates vault, folder, and file objects
        Dim vault As IEdmVault15
        Dim filename As IEdmFile11
        Dim file As IEdmFile11
        Dim fileID As Integer
        Dim fold As IEdmFolder8
        Dim enumvar As IEdmEnumeratorVariable9
        Dim COAffectedParts As String
        vault = New EdmVault5
        'logs into the vault "Test"
        vault.LoginAuto("Test", 0)
        'sets file equal to the object with the path typed in and sets folder to the parent folder object of the file
        filename = vault.GetFileFromPath("C:\Test\Test\RelayMount.sldprt", fold)
        Dim _COAffectedParts As String
        fileID = filename.ID
        enumvar = filename.GetEnumeratorVariable
        If enumvar.GetVar("CO Affected Parts", "@", _COAffectedParts) Then
            COAffectedParts = _COAffectedParts.ToString
        Dim COAffectedParts1 As String = Replace(COAffectedParts, """", "")
        Dim COAffectedParts2() As String = Split(COAffectedParts1)
End Module
