0 Replies Latest reply on Jul 21, 2016 7:42 AM by Marcus Merideth
    Non Linear Rubber Buckling
    Marcus Merideth
      I am trying to model a rubber bumper with a hole in it.  Using a non force driven model the solution stops when the buckling occurs even if the force driver is greater than the buckling load.  Using a displacement driven model failure is reached at buckling.  I need to power thru the buckling and understand the complete force deflection curve of the assembly.  Using force control on the model. Arc length control cannot be used on a contact problem. The housing holding the rubber is modeled as rigid and the part applying the load is also considered rigid to simplify the model.
      Thanks!
      Suggestions?
