Add custom property - Stocksize, Sort Dimensions macro
Question asked by JOHN GEORGE on Jul 20, 2016
Latest reply on Jul 21, 2016 by Elmar Klammer
I tried to modify one of the bounding box macro from this forum and added few lines to sort the values in order (posted in another discussion)
I have couple of issues with the result
  • It returns the message box result correct, but custom property values are different (shows only 0 x 0 x 0)
  • When I change my part units to fractions, it shows error in line "arr(1) = Length"
Here is the full code
Can someone please help me to solve the issue?
Thanks!
Dim Part As SldWorks.ModelDoc2
Dim Height As Variant
Dim Width As Variant
Dim Length As Variant
Dim Corners As Variant
Dim retval As Boolean
Dim UserUnits As Variant
Const swDocPart = 1
Const swDocASSEMBLY = 2
'Enum swLengthUnit_e
Const swMM = 0
Const swCM = 1
Const swMETER = 2
Const swINCHES = 3
Const swFEET = 4
Const swFEETINCHES = 5
Const swANGSTROM = 6
Const swNANOMETER = 7
Const swMICRON = 8
Const swMIL = 9
Const swUIN = 10
'Enum swFractionDisplay_e
Const swNONE = 0
Const swDECIMAL = 1
Const swFRACTION = 2
Function DecimalToFeetInches(DecimalLength As Variant, Denominator As Integer) As String
  ' converts decimal inches to feet/inches/fractions
  Dim intFeet As Integer
  Dim intInches As Integer
  Dim intFractions As Integer
  Dim FractToDecimal As Double
  Dim remainder As Double
  Dim tmpVal As Double
  ' compute whole feet
  intFeet = Int(DecimalLength / 12)
  remainder = DecimalLength - (intFeet * 12)
  tmpVal = CDbl(Denominator)
  intInches = Int(remainder)
  remainder = remainder - intInches
  If Not (remainder = 0) Then
    If Not (Denominator = 0) Then
      FractToDecimal = 1 / tmpVal
        If FractToDecimal > 0 Then
          intFractions = Int(remainder / FractToDecimal)
          If (remainder / FractToDecimal) - intFractions > 0 Then
            intFractions = intFractions + 1
  Call FractUp(intFeet, intInches, intFractions, Denominator) ' Simplify up & down
  DecimalToFeetInches = LTrim$(Str$(intFeet)) & "'-"
  DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intInches))
  If intFractions > 0 Then
    DecimalToFeetInches = DecimalToFeetInches & " "
    DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intFractions))
    DecimalToFeetInches = DecimalToFeetInches & "/" & LTrim$(Str$(Denominator))
  DecimalToFeetInches = DecimalToFeetInches & Chr$(34)
End Function
Function FractUp(InputFt As Integer, InputInch As Integer, InputNum As Integer, InputDenom As Integer)
  While InputNum Mod 2 = 0 And InputDenom Mod 2 = 0
    InputNum = InputNum / 2
    InputDenom = InputDenom / 2
  Wend
  If InputDenom = 1 Then  ' Full inch
    InputInch = InputInch + 1
    InputNum = 0
    If InputInch = 12 Then  ' Full foot
      InputFt = InputFt + 1
      InputInch = 0
End Function
Sub SortDimensions()
    Dim arr(1 To 3) As Double
    arr(1) = Length
    arr(2) = Width
    arr(3) = Height
    SortArr arr
Sub SortArr(arr() As Double)
    Dim i As Long
    Dim j As Long
    Dim tmp As String
    Dim p As String
    For i = LBound(arr) To UBound(arr) - 1
        For j = i + 1 To UBound(arr)
            If arr(i) > arr(j) Then
                tmp = arr(i)
                arr(i) = arr(j)
                arr(j) = tmp
        Next j
    Next i
   MsgBox (arr(1) & " x " & arr(2) & " x " & arr(3))
Sub Main()
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim StockSize As String
Set Part = swApp.ActiveDoc
Set swModel = swApp.ActiveDoc
Set swCustProp = swModel.Extension.CustomPropertyManager("")
If Part Is Nothing Then     ' Did we get anything?
  MsgBox "You need to have a part or assy open at this point." & Chr$(13) & Chr$(10) _
          & Chr$(10) & "Open one and try again."
  Exit Sub
If (Part.GetType = swDocPart) Then
  Corners = Part.GetPartBox(True)         ' True comes back as system units - meters
ElseIf Part.GetType = swDocASSEMBLY Then  ' Units will come back as meters
  Corners = Part.GetBox(0)
Else
  MsgBox "This macro is only useful with a part or assy." & Chr$(13) & Chr$(10) & "Open one of those and try again."
  Exit Sub
UserUnits = Part.GetUnits()
Select Case Part.GetUnits(0)
  Case swMM
    ConvFactor = 1 * 1000
  Case swCM
  Case swMETER
    ConvFactor = 1
  Case swINCHES
    ConvFactor = 1 / 0.0254
  Case swFEET
    ConvFactor = 1 / (0.0254 * 12)
  Case swFEETINCHES
    ConvFactor = 1 / 0.0254  ' Pass inches through
  Case swANGSTROM
    ConvFactor = 10000000000#
  Case swNANOMETER
  Case swMICRON
  Case swMIL
    ConvFactor = (1 / 0.0254) * 1000
  Case swUIN
    ConvFactor = (1 / 0.0254) * 1000000
End Select
Height = Round((Abs(Corners(4) - Corners(1)) * ConvFactor), UserUnits(3)) ' Z axis
Width = Round((Abs(Corners(5) - Corners(2)) * ConvFactor), UserUnits(3))  ' Y axis
Length = Round((Abs(Corners(3) - Corners(0)) * ConvFactor), UserUnits(3)) ' X axis
' Check for either (Feet-Inches OR Inches) AND fractions.  If so, return Ft-In
If (UserUnits(0) = 5 Or UserUnits(0) = 3) And UserUnits(1) = 2 Then
  Height = DecimalToFeetInches(Height, Val(UserUnits(2)))
  Width = DecimalToFeetInches(Width, Val(UserUnits(2)))
  Length = DecimalToFeetInches(Length, Val(UserUnits(2)))
Call SortDimensions
StockSize = (arr(1) & " x " & arr(2) & " x " & arr(3))
  retval = Part.DeleteCustomInfo2("", "StockSize") 'Remove existing properties
  swCustProp.Add3 "Stocksize", swCustomInfoText, StockSize, 1 'Add latest values
