Hi All
I have a 4 configuration sub assembly with a virtual component that's driven by other components, which also have different configurations. Within the sub assembly the virtual component udpates fine, but when the sub assembly is used in a higher level assembly at different configurations, the virtual component simply displays as the last configuration used in the sub assembly.
Any help will be appreciated
Cheers - Anders
Hi Anders,
It seems to be working fine for me....
I can change between the two sub assembly configurations and the driven part is updating accordingly. wasnt this what you were looking for?
The changes are:
Create a new configuration for the driven part. So let say the driven part now has Config A and B
Use Config A in the 50mm Subassembly config.
Use Config B in the 100mm Subassembly config.
Please let me know if it works out for you! thanks
