I have a piping system which is in reality drilled, welded and tapped. I am having an issue creating the whole profile using a 3D sketch. I know I would be able to do this using separate planes at the points needed, however, if I wish to change measurements later, It would be much more difficult. Right now, I swept the outside portion, but was not able to do the branches. I have attached the drawing. Any help is appreciated.
Update:
I ended up using a structural member to do what I planned to do. I sketched and formed one side and mirrored it. It looks correct other than some open ends and the seam in the top piece. It was not able to merge. I might redo it and do one form instead of a form and mirror.
