What is the best way to create an External Surface Solid from a CREO 2.0 Assembly?
I need to show holes, but all internal components should be lumped into one solid block.
SW2014
Thanks!
You can use intersect tool (save the assembly as part and use intersect in the created part file).
OR simply save assembly as part selecting exterior faces option .
