What would be a good resource, or tutorial for me to use to
learn the basics of the mold tools available in SolidWorks? I don't
need detail on each, but I am interested in learning the best
approach to starting a mold design from a plastic part.
Currently I take advantage of the cavity feature only. I draw a cavity block and core block, insert them into an assembly along with the plastic part and from there I take advantage of the cavity feature to remove material from the core and cavity. I'm doing this to get by as I need to get work done, but I am sure that there are "proper" ways to do this. The problem isn't my ability to learn, but the experiance to know what's available to me.
The Cavity feature is not Mold Tools tool, it's just an assembly based part feature.
The Mold Tools are on their own toolbar, and are done in the part environment.
You start with the Parting LIne feature, which does a draft analysis and finds the PL of the part.
You add shut off surfaces to seal holes.
Then you create the Parting Surface, which is the most difficult part. SW is fairly limited in the kinds of parting surfaces that work well using the automated tools. Most real mold people do this manually (I'm not a real mold person, but I know a little bit about the process).
Then you use the Tooling Split to make the cavity and core blocks.
Finally you can use the Core tool to make core pins or side actions or whatever.
You've got to be pretty well versed in the basics of surface modeling to make much use of the Mold Tools.
There are other ways of making molds geometry manually, and you often have to use a lot of manual techniques even with the semi-automated tools.
