Macro for saving file as configuration name?
Question asked by John García on Jul 19, 2016
Latest reply on Aug 15, 2018 by Dan Pihlaja
I am currently making changes to a model with 100+ configurations and i'm writing a macro so it can be more time consuming. What i've got so far is a macro that rebuilds all the sheets in a drawing then goes back to the first sheet and opens up the save as box. I would like to make it so it saves the file in a specific location as the configuration name. Here is what i have so far:
'Rebuilds all sheets and saves document as the current configuration name
    Set swModel = swApp.ActiveDoc
    Dim SheetNames              As Variant
    Dim Part                    As Object
    Dim SheetCount              As Integer
    Dim i                       As Integer
    Dim boolstatus              As Boolean
    Dim IncludeUnsaved          As Boolean
    Dim bool                    As Boolean
    'get all sheet names
    SheetNames = swModel.GetSheetNames
    'get total number of sheets
    SheetCount = swModel.GetSheetCount
    For i = 0 To SheetCount - 1
        retval = swModel.ActivateSheet(SheetNames(i))
        swModel.GraphicsRedraw2
        swModel.ViewZoomtofit2
                retval = swModel.ForceRebuild3(False)
        Debug.Print (i + 1)
    Next
    Set swApp = _
Set Part = swApp.ActiveDoc
    Dim ActiveView              As Object
    Dim PartName                As String
    Dim value                   As Boolean
    Dim FileName                As String
    IncludeUnsaved = True
Set ActiveView = Nothing
Part.ClearSelection2 True
'Goes to Sheet 1
boolstatus = Part.ActivateSheet("Drawing")
'Saves document as
swModel.Extension.RunCommand swCommands_SaveAs, Empty
