MMMatt McKendrick12/08/2008
I have to create a solid that represents the profile of a
part as it sweeps through an arc to create clearance in a mating
part. I am not aware of a method to "sweep" or "revolve" a body and
I am wondering if any of you extremely clever individuals have
figured out a method of doing this. Obviously the Sweep, Loft and
Revolve features only let you perform those functions on sketches.
The closest I have been able to get with this is to create a
circular pattern at the desired angle about the center of the arc I
want to sweep the body through and give it a large number of
instances (see attached). Unforturnately, Solidworks will not allow
me to combine the resulting bodies together, I suspect because it
creates alot of weird geometry and intersections. Any suggestions
would be greatly appreciated.
Thanks!
Thanks!
