1-1NHKU5
How do you deal with sheet metal gauge?
Discussion created by 1-1NHKU5 on Aug 12, 2008
Probably a question for M. G. Martinez, if you are watching.
The design is a top-down assy where everything is referenced to sketches/planes at the top:
Including the thickness of sheetmetal might be needed in order to be able to mate or reference features or assemblies to one side or the other of a sheetmetal part.
However, the issue here is that in general terms, I think it is better practice to use gauge tables when making sheet metal parts. If you want to avoid mating or refering to surfaces within sub-assembly sheet metal components you have to include sketch lines at the top level to reflect the thickness of the sheet metal being used. This poses a problem because you can't lock your bend table thickness selection to a dimension on a sketch . So, if you change the metal gauge at the part level you have to remember to go back to the top level assy and change your sketch to match. This, I think, "breaks" a nice top-driven parametric design.
The way I see it, if you want to be fully top-down, you can't use bend tables.
Am I missing something?
-Martin
