All,
I created the attached part and wanted to create it out of sheetmetal. Looking for tips on how to get there.
The highlighted green radi, is where I am assuming the fab house is going to have to weld two pieces together to make my part.
Cheers,
Jack
John,,, you might want to take a look at this. It actually was quite easy. I used your geometry but first changed the outside fillet radius to something smaller in order to close the gaps for welding. For manufacturing purposes it does not matter what the radius is in the model. I usually use something really small like .010" or less. That does not effect your overall dimensions. I offset your surfaces (0), then thickened, then did an insert bends. I did suppress your c'snks prior to offsetting then used your holes wizard sketch points to place new c'snks in the new sheet metal. As a former brake operator (and everything else) this is a nice break from the mundane. Not too hard - not too easy.
I did this over your model so you can unhide yours and compare. Looks like the flat could be easily punched so you can get the c'snks in the turret also. Or they might want to do a punch laser combo.
