problem with refplane.transform
Question asked by Yubo Hu on Jul 18, 2016
Latest reply on Jul 19, 2016 by Yubo Hu
Here i made a VBA code but always can not make it run, I tried to move the refplane by using transform property, but problems comes when I tried to assign doubler numbers to the transform matrix.
1. the code in red color is where error comes.
--------------------------START OF CODES------------------------------
Option Explicit
Dim swFeat As SldWorks.Feature
Dim swRefPlane As SldWorks.RefPlane
Dim swExten As SldWorks.ModelDocExtension
Dim swUtility As SldWorks.MathUtility
Dim swTrans As SldWorks.MathTransform
Dim trans() As Variant
Dim boolstatus As Boolean
Dim i As Integer
Set swModel = swApp.ActiveDoc
Set swPart = swModel
Set swExten = swModel.Extension
boolstatus = swExten.SelectByID2("Plane2", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
Set swRefPlane = swFeat.GetSpecificFeature2()
MsgBox swRefPlane.Name & swRefPlane.GetTypeName
trans() = Array(1, 0, 0, 0, 1, 0, 0, 0, 1, 0.2, 0, 0, 1, 0, 0, 0)
For i = 0 To 15
  swTrans.ArrayData(i) = CDbl(trans(i))
Next i
Set swTrans = swRefPlane.transform
---------------------------END OF CODE------------------------------
2. the error popup is as following
could anyone help me with this issue?
thanks.
