Macro modify
Question asked by Antonio Cavka on Jul 18, 2016
Latest reply on Jul 21, 2016 by Antonio Cavka
Hi all,
I have a macro that displays all dimensions from part in custom properties...
How can i modify that macro to display the biggest dimension  first and smallest at last?
Here is macro:
' * This macro gets the bounding box dimensions for the custom specific
' * It checks to make sure you have a proper document open.
' * It checks & utilizes the user units.
' * Modified by Wayne Tiffany, Oct 12, 2004
' * Updated 10/15/04
' * Original few lines of demo code by someone else (unknown).  Fraction
' * converter original code from rocheey.  3D sketch original code from
' * SW help.
' * Modified on July 11, 2016
Dim Part As SldWorks.ModelDoc2
Dim Height As Variant
Dim Length As Variant
Dim Width As Variant
Dim Corners As Variant
Dim retval As Boolean
Dim UserUnits As Variant
Const swDocPart = 1
Const swDocASSEMBLY = 2
'Enum swLengthUnit_e
Const swMM = 0
Const swCM = 1
Const swMETER = 2
Const swINCHES = 3
Const swFEET = 4
Const swFEETINCHES = 5
Const swANGSTROM = 6
Const swNANOMETER = 7
Const swMICRON = 8
Const swMIL = 9
Const swUIN = 10
'Enum swFractionDisplay_e
Const swNONE = 0
Const swDECIMAL = 1
Const swFRACTION = 2
Function DecimalToFeetInches(DecimalLength As Variant, Denominator As Integer) As String
  ' converts decimal inches to feet/inches/fractions
  Dim intFeet As Integer
  Dim intInches As Integer
  Dim intFractions As Integer
  Dim FractToDecimal As Double
  Dim remainder As Double
  Dim tmpVal As Double
  ' compute whole feet
  intFeet = Int(DecimalLength / 12)
  remainder = DecimalLength - (intFeet * 12)
  tmpVal = CDbl(Denominator)
  intInches = Int(remainder)
  remainder = remainder - intInches
  If Not (remainder = 0) Then
    If Not (Denominator = 0) Then
      FractToDecimal = 1 / tmpVal
        If FractToDecimal > 0 Then
          intFractions = Int(remainder / FractToDecimal)
          If (remainder / FractToDecimal) - intFractions > 0 Then
            intFractions = intFractions + 1
  Call FractUp(intFeet, intInches, intFractions, Denominator) ' Simplify up & down
  DecimalToFeetInches = LTrim$(Str$(intFeet)) & "'-"
  DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intInches))
  If intFractions > 0 Then
    DecimalToFeetInches = DecimalToFeetInches & " "
    DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intFractions))
    DecimalToFeetInches = DecimalToFeetInches & "/" & LTrim$(Str$(Denominator))
  DecimalToFeetInches = DecimalToFeetInches & Chr$(34)
End Function
Function FractUp(InputFt As Integer, InputInch As Integer, InputNum As Integer, InputDenom As Integer)
  While InputNum Mod 2 = 0 And InputDenom Mod 2 = 0
    InputNum = InputNum / 2
    InputDenom = InputDenom / 2
  Wend
  If InputDenom = 1 Then  ' Full inch
    InputInch = InputInch + 1
    InputNum = 0
    If InputInch = 12 Then  ' Full foot
      InputFt = InputFt + 1
      InputInch = 0
End Function
Sub Main()
Set Part = swApp.ActiveDoc
If Part Is Nothing Then     ' Did we get anything?
  MsgBox "You need to have a part or assy open at this point." & Chr$(13) & Chr$(10) _
          & Chr$(10) & "Open one and try again."
  Exit Sub
If (Part.GetType = swDocPart) Then
  Corners = Part.GetPartBox(True)         ' True comes back as system units - meters
ElseIf Part.GetType = swDocASSEMBLY Then  ' Units will come back as meters
  Corners = Part.GetBox(0)
Else
  MsgBox "This macro is only useful with a part or assy." & Chr$(13) & Chr$(10) & "Open one of those and try again."
  Exit Sub
UserUnits = Part.GetUnits()
Select Case Part.GetUnits(0)
  Case swMM
    ConvFactor = 1 * 1000
  Case swCM
  Case swMETER
    ConvFactor = 1
  Case swINCHES
    ConvFactor = 1 / 0.0254
  Case swFEET
    ConvFactor = 1 / (0.0254 * 12)
  Case swFEETINCHES
    ConvFactor = 1 / 0.0254  ' Pass inches through
  Case swANGSTROM
    ConvFactor = 10000000000#
  Case swNANOMETER
  Case swMICRON
  Case swMIL
    ConvFactor = (1 / 0.0254) * 1000
  Case swUIN
    ConvFactor = (1 / 0.0254) * 1000000
End Select
Width = Round((Abs(Corners(4) - Corners(1)) * ConvFactor), UserUnits(3)) ' Z axis
Height = Round((Abs(Corners(5) - Corners(2)) * ConvFactor), UserUnits(3))  ' Y axis
Length = Round((Abs(Corners(3) - Corners(0)) * ConvFactor), UserUnits(3)) ' X axis
' Check for either (Feet-Inches OR Inches) AND fractions.  If so, return Ft-In
If (UserUnits(0) = 5 Or UserUnits(0) = 3) And UserUnits(1) = 2 Then
  Height = DecimalToFeetInches(Lenght, Val(UserUnits(2)))
  Length = DecimalToFeetInches(Width, Val(UserUnits(2)))
  Width = DecimalToFeetInches(Height, Val(UserUnits(2)))
  retval = Part.DeleteCustomInfo2("", "StockSize") 'Remove existing properties
  retval = Part.AddCustomInfo3(ConfigName, "StockSize", swCustomInfoText, _
           Height & " x " & Width & " x " & Length)  'Add latest values
  Exit Sub
''End If
