I have a very large assembly. The main frame is a welded sheet metal structure and there are some heavy internal components.
It is supported on four corners by leveling feet. I would like to determine the weight supported by each leveling foot.
Any thoughts on this?
That's easy, place a roller-slider constraint on the bottom of each of the feet. You will have to add a small edge restraint somewhere for x-y stability of the model, say, the edge of one of the feet, and check it to make sure it isn't very much.
However, referring back to my Physics 101 days in college, this is an easy hand calculation.
