In an assembly, I want to know the weight of a subassembly or a part of the assembly.
How can I check the weight of that part or subassembly without opening up that subassembly or part and then check mass properties individually?
David
David
As a general reply as well, we list weights on almost every drawing.
Parts (details)
Assemblies, (generally an ERGO requirement, changeover tooling)
Assemblies with customer parts (generally an ERGO requirement & Machine Load Capacity)
There are many conditions where the mass property is really valuable.
Select the parts either on screen or in the tree. Then select Mass Properties on the evaluate tab.
