Noticed this today as well. I have an assembly that I must show the COG but it does not locate itself in the correct spot when the assembly view has a break. This seems like a recent issue, as I have never come across it myself, but then again it could have been there for years in the programming. This is in fact the first time, surprisingly, that I have added a broken section into an assembly that also contains the COG.
What do you mean? The COG is calculated in the Solid Model/Assembly. When you import the COG into the drawing, it should remain in the same location. When you add a break to the drawing view, whatever the distance of the break is, is how far off the COG adjusts due to the break.
