Cut List Ballons Not Updating on Multi Sheet Drawing
Question asked by Scott M. on Jul 14, 2016
Latest reply on Jul 14, 2016 by Glenn Schroeder
Condition:
Multi sheet drawing with a weldment drawing and cut list on sheet one and item details with balloons on following sheets
Problem:
Balloons on sheet 2,3, etc do not update to reflect changes on sheet one, even with doing a 'rebuild'.
If the balloon on sheet 2,3 etc is re-positioned or re-attached followed by a re-build they will update to match sheet one.
If an additional cut list is inserted on sheet 2,3, etc the balloons will update with a re-build only to match sheet one...it does not require re-positioning or re-attaching.
However, since cut lists can not be linked(SW glitch?) the 'additional' cut list will not necessarily match the cut list on sheet one so it must be hidden to avoid conflicts.
Desired Function:
Balloons on all sheets to update with changes to sheet one on rebuild without adding an addtional cut list to each sheet.
Any help would be much appreciated...
-Scott
