Re: Design Library Toolbox Icons.....
Dave Bear Jul 15, 2016 10:35 PM (in response to Dave Bear)No suggestions anybody????
Anna Wood Jul 16, 2016 1:00 AM (in response to Dave Bear)Nope....
Nadjaran Tehupelasury Jan 30, 2018 10:17 AM (in response to Dave Bear)Hi Dave,
Even though this discussion is out-of-date I can still provide you with some information.
It seems that the folder icons are hardcoded into the Toolbox-software. So you can't assign your own icons to the Toolbox folders or files, but you can use theirs. It's a bit devious, but when you rename a folder into a Toolbox familiar name, the folder icon will automatically change after you've saved your Toolbox. For example: Rename a folder into 'Rivets'. It will look like this after you saved:
It seems that the software recognizes the name and automatically changes the layout. You're able to add text after the core name (ex. Rivets & Studs), but do not put anything before the core name of the folder. It will change the icon of the folder to the default layout.
Toolbox familiar names are (if I looked correctly):
- Bearings
- Bolts
- Screws (same as Bolts)
- Keys
- Nuts
- O-Rings
- Pins
- Power Transmission
- Retaining Rings
- Structural Members
- Washers
- Jig Bushings
- Rivets
- Studs
- Seals
You can also copy-paste existing folders to maintain the layout and fill them with your own content.
Dave Bear Jan 30, 2018 6:18 PM (in response to Nadjaran Tehupelasury)
