3 Replies Latest reply on Mar 14, 2018 2:17 PM by Hepzibah Chandranand
    CoordinateSystemFeatureData
    Wilfried Pietz
      i write a new Function to bring me back the Origin of the selected CoordinateSystem. But i do not work
      Public Function SetCoordSys(ByVal csys As String) As Boolean
           If m_ModelDoc Is Nothing Then
                Me.ErrTextKomp(My.Resources.FehlerTexte.DF_SwModeldocNothing, "SetCoordSys", ErrText)
                Return False
           SetCoordSys = False
           Dim boolstatus As Boolean
           Dim cSysData As CoordinateSystemFeatureData
           Dim CoordSys As Feature
           Dim geo As SldWorks.Entity
           'Koordinatensystem selektieren
           Dim swSelmgr As SldWorks.SelectionMgr = m_ModelDoc.SelectionManager
           boolstatus = m_ModelDoc.Extension.SelectByID2(csys, "COORDSYS", 0, 0, 0, False, 0, Nothing, 0)
           If boolstatus = True Then
                CoordSys = swSelmgr.GetSelectedObject6(1, -1) 'CoordSys is OK, i can see the right information
                cSysData = CoordSys.GetDefinition()
                geo = cSysData.OriginEntity()' This entry is nothing why???
           SetCoordSys = True
      End Function
      I want this information
      Thank you for your support
      Wilfried
      Nachricht geändert durch Wilfried Pietz marked wrong line
        • Re: CoordinateSystemFeatureData
          Artem Taturevych
          Try
          cSysData.AccessSelections(m_ModelDoc, Nothing)
              Wilfried Pietz
              Yes, you're right, correct answer for the code.
              But not for my problem. My approach was just completely wrong
              Here is my solution
              Public Function GetCoordSysInfo(ByVal csys As String) As List(Of List(Of String))
                      GetCoordSysInfo = New List(Of List(Of String))
                      If m_ModelDoc Is Nothing Or csys.Length < 1 Then
                          Me.ErrTextKomp(My.Resources.FehlerTexte.DF_SwModeldocNothing, "GetCoordSysInfo", ErrText)
                      Else
                          Dim CoordSys As SldWorks.Feature
                          Dim swFeature As SldWorks.Feature
                          'Koordinatensystem suchen
                              ' Eltern und Kinderelemente auslesen
                              Dim Parents As Object = CoordSys.GetParents
                              Dim Children As Object = CoordSys.GetChildren
                              Dim PLST As New List(Of String)
                              Dim CLST As New List(Of String)
                              Dim varobj As Object
                              For Each varobj In Parents
                                  swFeature = varobj
                                  PLST.Add(swFeature.Name)
                              Next varobj
                              GetCoordSysInfo.Add(PLST)
                              If Not IsNothing(Children) Then
                                  For Each varobj In Children
                                      swFeature = varobj
                                      CLST.Add(swFeature.Name)
                                  Next varobj
                                  GetCoordSysInfo.Add(CLST)
                  End Function
              Reslt:
              Thanke you for your support
              Wilfried
              How do you get the full names of the entities in the coordinate system data
