In sheetmetal Flattern view, Hole dimension is changed and in normal view it shows correct. Please find the below image.
Thanks & Regards,
Poornakkumar P
Thanks & Regards,
Poornakkumar P
It is possible that the flat pattern isn't showing flat to screen. Open up the part and go to your flat pattern configuration and hit normal too, then hit the spacebar and make a new view called Flat, then in your drawing sheet add the flat pattern again and have it come in orientated to the new view...
Another thing to check... did you scale your part or draw it 1:1
Can you check and make sure that dimensions is not different for folded and flatten configuration in the part. Can you attach the part file to check?
