5 Replies Latest reply on Jul 13, 2016 3:41 PM by Edwin Thompson
    Trouble with example code
    Edwin Thompson
      I'm trying to follow an example but am not sure how to address the error:
      The code that was copied is shown below.  The error is shown at the bottom.
      Any ideas how to fix this are very appreciated.  Any explanation of the "bigger picture" would also be very helpful.... thank you.
      'following dim's are for Holewizard example
              Dim swModel As ModelDoc2
              Dim swModelDocExt As ModelDocExtension
              Dim swFeatMgr As FeatureManager
              Dim swFeat As Feature
              Dim swSketchMgr As SketchManager
              Dim sketchLines As Object
              Dim status As Integer
              Dim boolstatus As Boolean
              Dim P1(2) As Double
              Dim P2(2) As Double
              Dim P3(2) As Double
              ' Create the model for the wizard hole
              swApp.ResetUntitledCount(0, 0, 0)
              swModel = swApp.NewDocument("C:\Documents and Settings\All Users\Application Data\SOLIDWORKS\SOLIDWORKS 2014\templates\Slot Test Part.prtdot", 0, 0, 0)
              swApp.ActivateDoc2("Part1", False, status)
              swModel = swApp.ActiveDoc
              swSketchMgr = swModel.SketchManager
              swModelDocExt = swModel.Extension
              swFeatMgr = swModel.FeatureManager
              sketchLines = swSketchMgr.CreateCornerRectangle(-0.05096498314664, 0.05060941349678, 0, 0.1021670127265, -0.05037236706354, 0)
              boolstatus = swModelDocExt.SelectByID2("Line2", "SKETCHSEGMENT", 0, 0, 0, False, 0, Nothing, 0)
              boolstatus = swModelDocExt.SelectByID2("Line2", "SKETCHSEGMENT", 0, 0, 0, True, 0, Nothing, 0)
              swFeat = swFeatMgr.FeatureExtrusion2(True, False, False, 0, 0, 0.381, 0.381, False, False, False, False, 0.01745329251994, 0.01745329251994, False, False, False, False, True, True, True, 0, 0, False)
              'Create three points for the reference plane
              P1(0) = -0.0141556764402858
              P1(1) = 0.00194061273859598
              P1(2) = 0
              P2(0) = -0.0141556764402858
              P2(1) = 0.00194061273859598
              P2(2) = 1
              P3(0) = -0.149976101832345
              P3(1) = -0.988792859011662
              P3(2) = 0
              'Create the reference plane
              swModel.CreatePlaneFixed2(P1, P2, P3, False)
              'Select the reference plane
              boolstatus = swModelDocExt.SelectByID2("Plane1", "PLANE", -0.0156784487003801, -0.00916715285390111, 0.0558270998665543, False, 0, Nothing, 0)
              ' Create the hole wizard hole
             swFeat = swFeatMgr.HoleWizard5(swFeatMgr.swWzdGeneralHoleTypes.swWzdCounterSink, swModel.swWzdHoleStandards.swStandardAnsiMetric, swModel.swWzdHoleStandardFastenerTypes.swStandardAnsiMetricFlatHead82, "M2", swModel.swEndConditions.swEndCondThroughAll, 0.0102, 0.010312189893273, 0, 0.0044, 1.57079632679489, 0.000152189893272978, 0, 2.05948851735331, 0, 0, 0, 1, 0, 0, 0, "", False, True, True, True, True, False)
        • Re: Trouble with example code
          Viktor Bovzdarenko
          Hi Edwin
          There were a few issues with the macro
          try corrected one with the following result:
          Option Explicit
          Sub Main()
              swApp.ResetUntitledCount 0, 0, 0
              Set swModel = swApp.NewDocument("C:\ProgramData\SolidWorks\SOLIDWORKS 2015\templates\Part.prtdot", 0, 0, 0)
              Set swModel = swApp.ActiveDoc
              Dim sketchLines As Variant: sketchLines = swModel.SketchManager.CreateCornerRectangle(-0.05096498314664, 0.05060941349678, 0, 0.1021670127265, -0.05037236706354, 0)
              swModel.SketchManager.InsertSketch True
              Dim boolstatus As Boolean: boolstatus = swModel.extension.SelectByID2("Sketch1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
              Dim swFeat As Feature: Set swFeat = swModel.FeatureManager.FeatureExtrusion2(True, False, False, 0, 0, 0.381, 0.381, False, False, False, False, 0.01745329251994, 0.01745329251994, False, False, False, False, True, True, True, 0, 0, False)
              Dim P1(2) As Double
              Dim P2(2) As Double
              Dim P3(2) As Double
              P1(0) = -1.41556764402858E-02
              P1(1) = 1.94061273859598E-03
              P1(2) = 0
              P2(0) = -1.41556764402858E-02
              P2(1) = 1.94061273859598E-03
              P2(2) = 1
              P3(2) = 0
              swModel.CreatePlaneFixed2 P1, P2, P3, False
              boolstatus = swModel.extension.SelectByID2("Plane1", "PLANE", -1.56784487003801E-02, -9.16715285390111E-03, 5.58270998665543E-02, False, 0, Nothing, 0)
              Set swFeat = swModel.FeatureManager.HoleWizard5(1, 1, 36, "M2", 1, 0.0102, 0.010312189893273, 0, 0.0044, 1.57079632679489, 1.52189893272978E-04, 0, 2.05948851735331, 0, 0, 0, 1, 0, 0, 0, "", False, True, True, True, True, False)
              Edwin Thompson
              Everything looks good except for the last line:
              swFeat = swFeatMgr.HoleWizard5(swWzdGeneralHoleTypes_e.swWzdCounterSink, swWzdHoleStandards_e.swStandardAnsiMetric, swWzdHoleStandardFastenerTypes_e.swStandardAnsiMetricFlatHead82, "M2", swEndConditions_e.swEndCondThroughAll, 0.0102, 0.010312189893273, 0, 0.0044, 1.57079632679489, 0.000152189893272978, 0, 2.05948851735331, 0, 0, 0, 1, 0, 0, 0, "", False, True, True, True, True, False)
              I don't understand the "_e" term of the code but VB.net is claiming that they are not declared.
              Can you please explain what these modifiers are intended to do.
              I did remove the "_e" and added the "swFeatMgr." to each of the terms.  However the line still results in an error.
              swFeat = swFeatMgr.HoleWizard5(swFeatMgr.swWzdGeneralHoleTypes.swWzdCounterSink, swFeatMgr.swWzdHoleStandards.swStandardAnsiMetric, swFeatMgr.swWzdHoleStandardFastenerTypes.swStandardAnsiMetricFlatHead82, "M2", swFeatMgr.swEndConditions.swEndCondThroughAll, 0.0102, 0.010312189893273, 0, 0.0044, 1.57079632679489, 0.000152189893272978, 0, 2.05948851735331, 0, 0, 0, 1, 0, 0, 0, "", False, True, True, True, True, False)
              I really appreciate your help.
              Edwin Thompson
              It has been 4 years since I worked on this project, It is amazing what one can forget.  Thank you for the help.
