I am looking for a way to name our drawing files using the configuration name as the default. (instead of part/assembly name)
When you select "Make Drawing from Part" the drawing window opens and is named with the part/assembly name.
Is it possible to change this to default to the active configuration name?
Ex:(default behavior)
part = 010203xx
configuration name = 01020301
drawing name = 010203xx
Ex:(modified behavior)
part = 010203xx
drawing name = 01020301
SW2016 SP3 Standard
NO, you'll have to do that manually or via a macro
