Add Equation to selected part
Question asked by Yannick Proulx on Jul 11, 2016
Latest reply on Jul 11, 2016 by Amen Allah Jlili
Hi Guys,
I'm trying to add an equation to a part.
If I run my code when ModelDoc is swapp.activeDoc then everything work fine, my equations are added without any problem.
If I try to add my equation from an assembly through the selectionManager it's not working.
I get my modelDoc in an assembly through this way : swcomp2 = swSelMgr.GetSelectedObjectsComponent2(i)
then convert to modelDoc2 by modelDoc = swcomp2.getmodeldoc2
i get the swEquationMgr.GetCount to work so the equationMgr is correctly connected.
but when i Try to add the equation I get -1 which mean equation was not added...
is it possible that you cannot add an equation from else where that the activeDoc??
thanks for your time
Yannick
   Function link_equation(modeldoc As SldWorks.ModelDoc2, dimensionName As String, propertyName As String) As Boolean
        Debug.Print(modeldoc.GetPathName)
        Dim swEquationMgr As SldWorks.EquationMgr = modeldoc.GetEquationMgr
        Dim EquationStr As String = """" & dimensionName & """ = """ & propertyName & """"
        If swEquationMgr Is Nothing Then
            MsgBox("impossible d'atteindre le EquationMgr de la pièce " & modeldoc.GetPathName)
            Return False
        Dim equationResult As Integer = 0
        Dim I As Integer
        Debug.Print("Equation Count : " & swEquationMgr.GetCount) '<------------------ work fine here I get the Equation count
        For i = 0 To swEquationMgr.GetCount - 1
            If UCase(swEquationMgr.Equation(I)) = UCase(EquationStr) Then
                Return True 'equation already exist
        Next
            Debug.Print(EquationStr)
            If swEquationMgr.GetCount = 0 Then
                If swEquationMgr.Add2(0, EquationStr, False) = -1 Then '<-------------------return 0 (ok) when modelDoc = activedoc and return -1 in assy
                    Debug.Print("equation not added")
                    Return False
            Else
                If swEquationMgr.Add2(-1, EquationStr, False) = -1 Then
                    Return False
        Return True
    End Function
