I'm relatively new to the program, but here's the basics: I've got a simple assembly with two posts at angles. I need to drop a hole through the top surface of each post, but I need to be able to change the angle of the post. I'm changing it by altering the parent sketch in the part - I was hoping the sketch would stay constrained to the surface in the assembly, but it looks like it's deleting the face and making a new one so the constraints all crash.
Is there another way I should be going about changing the post to avoid this problem?
Timothy,
I deleted the vertical relation from within 'Sketch2' (part of 'Cut-Extrude1'). This allowed the sketch to find a solution.
I could then edit the sketch that created the post and the hole stayed in the post and concentric to the hole in the plate.
David
