H there,
I made an assembly and brought it into Visualize and for some reason it only shows half of the model except for when I move the camera to the floor. If I raise anything above that point the bottom half of the model disappears.
Its the first time I have used visualise as I downloaded the trial version and perhaps its something I did wrong.
Thanks.
This is because your model is crossing the standard planes and by default the top plane is set as an opaque ground in the scene properties.
This not a big issue.
1- If you go to the Model tab on the right of the interface, you can select your model in the model set list
2-in the properties of this model, you will find all you need to rotate the model to your needs and snap it to the floor.
You can also use the center command if the model is to far from the world origin, and the Autosize command to fit its size to the world scale.
Please note that the model have to fit in the environment sphere (its size can be set in the Scene properties).
Regards.
