I have a doubt with the units used in Sustainability for the electricity of the manufacturing process. I'm using the Spanish version of Solidworks and in the panel where I introduce the data, it appears "kWh/gm" (gm=grams I think). But, when I get the Sustainability Report (in doc. format) it appears "kWh/lbs" (lbs=libras=pounds in Spanish) with the same number that I wrote in the panel as "kWh/gm". So, which unit is the right one? Which unit does the Sustainability use to do the calculations? I hope somebody could help me.
