YNYong Ning09/07/2016
BOM Scaling
Lets you scale the BOM size. Available only after you click the pan icon  in the upper left corner of an existing bill of materials in a part or assembly.
no find API code of bom scaling. follow code is replace code.
Private Sub eAsmFile()
    Dim Xls As Excel.Application, Rng As Range, oRng As Range
        Set Xls = GetObject(, "Excel.Application")
    Dim Path
        Path = Xls.ActiveWorkbook.Path & "\PDF\"
    Dim Sht As Worksheet, Str
        Set Sht = Xls.Worksheets("JB4715")
        Set Rng = Sht.Cells(1, "BH").CurrentRegion
    Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
        Set SwApp = Application.SldWorks
        Set SwModel = SwApp.ActiveDoc
    Dim sFileName
        SwApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveSelected
    Dim nErrors As Long, nWarnings As Long
     'Dim fileConfig As String, fileDispName As String, fileOptions As Long
        For jj = 1 To Rng.Columns.Count
             Set oRng = Xls.Range(Rng(2, jj).Formula)
             Debug.Print oRng.Address
             Str = ""
             For ii = 1 To oRng.Rows.Count
                 Str = oRng(ii, 1) & Chr(10) & Str
             Next ii
             sFileName = Rng(1, jj) & ".eAsm"
             sFileName = Path & sFileName
''             Stop
             Debug.Print sFileName
             SwApp.SetUserPreferenceStringListValue swUserPreferenceStringListValue_e.swEmodelSelectionList, Str
             SwModel.Extension.SaveAs sFileName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, nErrors, nWarnings
        Next jj
Private Sub del20160707()
       Set Sht = Xls.Worksheets("GeneralTable")
       Set Rng = Sht.Cells(5, "AK")
       ''Debug.Print Rng.Parent.Name
   Dim Str, tmp, ii, jj, Xx, Yy, Row
       Str = "材料明细表"
   Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
   Dim SwSelMgr As SelectionMgr
       Set SwSelMgr = SwModel.SelectionManager
   Dim sConfNames(0) As String, bVisible(0) As Boolean
   Dim SwAnn As Annotation, Pp
   Dim SwTextFormat As TextFormat
   Dim ConfArr, swConf As Configuration
       ConfArr = SwModel.GetConfigurationNames
   Dim SwBomFeat As BomFeature, SwTabAnn As TableAnnotation
   Dim SwBomTab As BomTableAnnotation, BomTab As BomTable
       'For ii = UBound(ConfArr) - 1 To UBound(ConfArr) - 1
       For ii = 0 To UBound(ConfArr)
           SwModel.ShowConfiguration2 ConfArr(ii)
           Set swConf = SwModel.GetActiveConfiguration
           tmp = SwModel.Extension.SelectByID2(Str, "BOMFEATURE", 0, 0, 0, False, 0, Nothing, 0)
           Set SwBomFeat = SwSelMgr.GetSelectedObject5(1)
           SwBomFeat.Configuration = swConf.Name
           sConfNames(0) = ConfArr(ii) 'ConfName
           bVisible(0) = True
           ConfNames = sConfNames
           SwBomFeat.SetConfigurations False, bVisible, ConfNames
           ''Debug.Print ii, SwBomFeat.Configuration, swConf.Name, SwBomFeat.Configuration = swConf.Name
           'Set SwBomTab = SwBomFeat
           Set SwBomTab = SwBomFeat.GetTableAnnotations(0)
           Set SwTabAnn = SwBomTab
           With SwTabAnn
               ''Debug.Print .Type, .Type
               For jj = 0 To .ColumnCount - 1
                    .Text(0, jj) = Rng(1, jj + 1)
                    'Rng(0, jj + 1) = Int(.GetColumnWidth(jj) * 1000)
                    .SetColumnWidth jj, Rng(0, jj + 1) / 1000, 0
               Next jj
               Set SwAnn = .GetAnnotation
               Xx = Rng(2, 1) / 1000
               Yy = Rng(2, 2) / 1000
               SwAnn.SetPosition Xx, Yy, 0
               For Row = 0 To .RowCount - 1
                    .SetRowHeight Row, 180 / 1000, 0
               Next Row
           End With
           Set SwTextFormat = SwAnn.GetTextFormat(0)
           With SwTextFormat
               '.CharHeight = 0.2 '200 / 1000
               '.TypeFaceName = "黑体"
           End With
           'SwAnn.SetTextFormat 0, False, swtextfomrat
           DigitsSwAnn SwTabAnn '
           'SwModel.EditRebuild3
       Next ii
