So I created a solid part that features a series of holes inside a part with fillet edges. I then offset the hole and thickened it to create a part that can rotate inside the larger one. How do I fill in this hole? Tried knitting, filling in the surface (none work), and when thickening it I don't get the option to "create solid from enclosed volume", which would be ideal.
(trying to completely fill in the red hollow rotating piece in the middle)
Robert,.. close the two open ends by using "fill surface" and add/knit them.. then, change your thicken option to "create solid from enclosed volume"
