Hello
Does anybody know how to change default path TEMP folder for Solidworks?
Regards
Marcin
Change here
Hello Deepak
Thanks for info.
Unfortunately I was not thinking about Temp folder for backup
I'am thinking abiut temp folder for SOLIDWORKS application...
Hi Marcin,
Did you receive an answer on this?
Can you check if Solution Id: S-013663 from SOLIDWORKS Knowledge base is the solution you looking for?
Am I missing something here - I just browser for a new folder - see below image
what the issue you have when you tried to change the temp folder ?
I think OP needs to set the temp directory for SOLIDWORKS application as shown in the Rx window.
Change here
