I had originally asked my VAR, but still have the issue.
I would like to crop a drawing view. When I select that option it asks for a closed sketch. So I draw a circle around the part I want visible, I then highlight the circle and select crop….
Everything in that drawing view disappears.
1.) I select the view.
2.) Select crop button, it states I need a closed sketch.
3.) I draw a closed spline, and nothing.
I delete the closed spline.
1.) I select the view, and create a closed spline around the part I want to be viewed.
2.) I select the crop view button and the entire view disappears. I check to see if it is hidden, and it is not. I do notice that the spline is moving with the drawing view now. That was something that didn’t happen before.
I pray this is not the issue, but could it be that I am trying to get a crop an ISO drawing view?
the attachment is a Pack n' Go.
In drawing view 3 I can get both the Spline and the Circle to crop view.
The views I am having issues cropping are;
Drawing View 4 [made with a circle]
Drawing view 5 [ made with a closed spline]
Many thanks for your help and assistance!
Lord Wukits
Solidworks 2016 SP3
I've taken a look at your drawing and the problem is that you're cropping a view with perspective on. I think this has been an issue for a while now, I've found and pasted the SPR that describes this below. If you use a non perspective view in your drawing you should hopefully have no issue cropping.
