I am trying to add a custom size of square tubing to toolbox. I can only get it to appear in assembly mode by going thru the design library. It does not show up in the list if I use the Toolbox pull down menu. I want to be able to use it in a weldment. How can I make it show up?
Brad
Brad,
I don't think you can add a brand new part in the toolbox, but you can add a custom size to the existing part (similar tube in the toolbox)
You can open the toolbox settings, customize your hardware option and select the standards and type
Click on add new size
Fill in all values and save
Hope this helps
