This would make drawing a lot easier.
Give a good reason why the shorter one should be selected? I can't think of one, which ever one is on top should be selected. Both Anna and Johns solutions get you to select the correct one.
Correct me if I'm wrong Ian, but I would imagine his reasoning would be that if the shorter line was always shown preference you could move to a different portion of the long line that is not overlayed with the short line when you need to select it.
If it were as such, then when you select the short one it will highlight it and make it evident where it ends making it easy to select the longer one if that's what you want.
The benefit would be a faster and more intuitive way to select any line, without having to research the other options.
Yeah you can do it other ways, but this would make the software more intuitive to use.
Do you know about RMB > Select Other after making a selection?
