Hi guys,
I am having trouble opening files in my 2013 solidworks, as every time I try to open specific files I get a window saying that the are from a future version, which they are not, and cannot me opened. Any ideas how to fix this?
Niall
Hi guys,
Niall
This ^^^^, or is someone's machine set to download updates by accident, and is now 14/15/16? The only way you should get this message is if they either are in fact from a future version, or your machine thinks it's pre 2013 (rare, but possible if you have/had multiple versions installed). In the latter case, unsinstall all Solidworks versions and do a clean install.
hei'ya Niall,
if you can upload a sample file-
possible to check the true version on the forums
if you have a restore point from working models-
maybe do a disk image first- and try from that date
check your system for *.bak files of your problem files
copy and rename to specific test file and see what is
all I got at the mo-
hope this helps- have a good'n kelef
Are you sure someone at work isn't accidentally playing with Beta to see what features are available?
