Is there any secret to get a linear pattern to follow a line rather than the x or y axis? I'd like to make a pattern using a construction line to determine the angle rather than an axis. If select the entities I want to pattern then select the line to set the direction it simply adds the line to the list of entities to pattern and retains the x axis as the direction.
This is still a limitation, please vote for SPR #: 815708 or ask you VAR to get you connected with this SPR.
