hi guys just want to ask about dell laptop inspiron 15 7000 can handle or run soldeworks 2016? thanks!
It is not on the SW-approved hardware list. That does not mean that it will not run but you could run across more problems than you could expect if you were using an approved system. It depends on how hard you expect to "push" it.
Also - the recommendations are that SW be run on Windows "Pro" version - it is not officially supported on Windows "Home" versions. Not sure which you have.
hey jeff already have my workstation its Hp Zbook14 G2
what do you think of the unit? how about the performance.
because its my first time to used a mobile workstation kinda missing a big screen.
Solidworks will run pretty well on this system provided the performance will smoother unless you try increaseasing no of separate part windows/features/ patterns, etc. Also The reviews says battery backup might be questionable. If the system consists of AMD card, It makes me bit worried of Solidworks Visualize which always need to be feeded with some extra resources
