2 Replies Latest reply on Jun 29, 2016 10:06 PM by Alin Vargatu
    Macro for thickening each selected face as an individual body.
    Alin Vargatu
      The model contains a number of faces that belong to one or more surface bodies.
      I would like to preselect a number of these faces type a value "T". The macro will:
      1. Copy each of the selected faces into a new and independent surface body
      2. Thicken all the new surface bodies with the thickness = "T" without merging the new solid bodies. If needed, the direction of the thickening could be changed.
      3. As an option, delete the old surface bodies. (not imperative)
      I found this macro, but does not seem to work in SW 2016. Wicked thickening challenge
      Any assistance will be greatly appreciated.
        • Re: Macro for thickening each selected face as an individual body.
          Viktor Bovzdarenko
          Hi Alin
          I also answered on another thread:Wicked thickening challenge
          Macro  works in SW16.
          Option Explicit
              On Error Resume Next
              Const Thickness As Double = -0.001
              Dim swApp              As SldWorks.SldWorks: Set swApp = CreateObject("SldWorks.Application")
              Dim swModel            As SldWorks.ModelDoc2: Set swModel = swApp.ActiveDoc
              Dim swSelMgr            As SldWorks.SelectionMgr: Set swSelMgr = swModel.SelectionManager
              Dim swSelData          As SldWorks.SelectData: Set swSelData = swSelMgr.CreateSelectData
              Dim swPart              As SldWorks.PartDoc: Set swPart = swModel
              Dim swBody              As SldWorks.Body2
              Dim swFace              As SldWorks.Face
              Dim swEnt              As SldWorks.Entity
              Dim i                  As Long
              Dim vBodies As Variant: vBodies = swPart.GetBodies2(swAllBodies, True)
              For i = LBound(vBodies) To UBound(vBodies)
                  Set swBody = vBodies(i)
                  Set swFace = swBody.GetFirstFace
                  Do Until swFace Is Nothing
                      Set swEnt = swFace
                      swFace.Select4 False, swSelData
                      swModel.InsertOffsetSurface Thickness, True
                      Set swFace = swFace.GetNextFace
                  Loop
                  swBody.Select2 False, swSelData
                  swModel.FeatureManager.InsertDeleteBody
              Next
                  Set swEnt = swFace
                  swSelData.Mark = 1
                  swModel.FeatureManager.FeatureBossThicken Thickness, 0, 96, False, False, False, False
              Next
