I have tried multiple forms of mating tubes to an end cap in order to create a sub assembly for a shell and tube heat exchanger; however, where the tubes meet the slot, the contact is never watertight. The diameter of the slot is the same as the outside diameter as the tube. I have created a different mate so that the tube would sit on a ridge in the slot creating two faces of contact, but still no luck. Any advice would be greatly appreciated.
Hi Adam,
Is the tubes surfaces? Try to make them solid first and see if that helps.
If not, could you attach the model so I can see what's going on?
Br,
Sindre
