When I turn sub-assemblies into virtual ones it used to ask me if I wanted to turn just the sub-assembly or also the parts within. I usually said just sub-assembly. This is not happening anymore. When I turn sub-assemblies into virtual ones it renames the whole tree to "copy of" without asking.
I've been searching in the option window, help, etc and I can't find the way to make it ask again.
Anyone can help me please?
Hi Sergio,
Have you checked in the "Messages/Errors/Warnings" section in the system options to see if you have dismissed the message? I.e you clicked on 'do not show me again' in which case it is not prompting you.
If this is the case it will be listed in the options with an empty check box. If you check the box, it will start reappearing again.
see screenshots.
Many Thanks,
Harneel
Solid Solutions
